Carburetor Cleaning & Tuning 101
Old 07-09-2009, 04:07 PM
Dissevered's Avatar
Default Carburetor Cleaning & Tuning 101
There are so many questions that are answered by cleaning or tuning your carbs so I decided to write up a "How to."
On a scale of 1-10, 10 being the hardest thing to do on a motorcycle, I rate Carb cleaning at a 4 and tuning at a 7. Some mechanical know how helps, but as long as you have the right tools, patience, and the willingness to learn, you will be fine.
On the pictures I have numbers. The numbers are not an order of which to do things, but just things I point out for you to keep note of.
This is just a guide to show you around the carburetor. A good tuning guide can be found at Factory Pro's website. Here is the link:
http://www.factorypro.com/tech_tunin...m_engines.html
Tools needed:
Screwdrivers - Flat head and Phillips, stubby and long
Pliers - not required but helps with pulling off some hose clamps
Wrenches - 7mm up to 12mm does most jobs on this bike.
Pilot screw adjuster - D shaped driver, but not needed with a little mod...
Remove Tail fairings, seat and gas tank (set the tank to OFF position first). If you can't get this far, then carbs are out of your league for the time being.
1. Breather hose - Be sure to reattach this when you put everything back together
Remove the air box cover, filter and everything else down to the carbs. Those only requires a phillips head, but an electric driver really speeds things up. As you can see there are a bunch of screws.
1. Another breather hose, pull it off and don't forget it later
2. Throttle cables
3. Choke cable
4. Gaskets, don't lose these
Pull off the rest of the air box
1. Vacuum hose that goes to the gas tank, another thing to not forget during reassembly
2. Carb Boot screw
Loosen up each screw on all four of these boots which are on the bottom of the carbs. They are a pain to get to. I use a stubby but I have small hands, you may need a long screw driver. Once loose, rock the carbs front to back to loosen them and pull up. This can be a chore if you have not taken them off for a while.
Now for the worst part of the job. Remove the throttle cables. Loosen up the throttle cables, slide them out of the holder and push the cable in closer toward the other end of the carburetor. This puts slack on the cable so that it is easier to remove.
1. This is where the throttle cables are locked in.
2. Idle adjuster screw - Just so you know where it is... If you look, you can see what it does as well. It just slightly opens the throttle plate.
There is no easy way to exlpain how to remove the cables. It sucks and it's a pain in the ****. You need to put enough slack in the cables in order to slide them out of the little holder. have fun.
1. Float bowl drain screw
Unscrew all of these and let the fuel drain out of the bowls. Do it somewhere you don't mind getting messy.
1. Float bowl screws
Take these out
1. Float
2. Float needle/valve
3. Float pin
Here is a common trouble area. The float and needle here are what regulate the fuel coming into the carbs. A bike that sits a few months without stabilizer in the carbs can get gunk in many places and this is a common one. Lift up on your floats gently and make sure the needle moves without sticking. If you are due for a cleaning, knock out the float pin in order remove the float and needle. Use carb cleaner and a scotchbrite pad to clean both the needle and the seat. Also the tip of the needle is rubber, be sure it still V shaped so that it seats properly.
1. Pilot/Slow jet adjustment screw
2. D shaped adjuster tool.
Pilot jets control how well your bike Idles, comes off of idle, and operates at cruising speed around 4k RPMs
*TIP* If you don't have one of these dumb tools, you can get a mini hack saw, or a hand grinder dremmel tool type thing and cut in a small slit down the center of the Pilot screw. This makes it adjustable with a standard flat head screw driver.
1. Main jet
2. Needle jet - Main jet screws into the top of this.
3. Pilot/Slow jet
More things to clean. Pretty much anything with a hole can get carb cleaner squirted into it and an air compressor is a very nice thing to have. It is not required but it makes everything 100x's easier. If you don't have an air compressor, I recommend unscrewing the 2 Jets with a flat head, then unscrewing the needle jet with a 7mm wrench and soaking all of them in carb cleaner over night.
WARNING! Do not get carb cleaner on anything non metal. It eats paint, it eats plastic and destroys rubber!
If you have a jet kit, this is 1 of the things you may have to tinker with. Main jets control the air/fuel mixture at high RPMS. There are numbers on the jets, a bigger number = a bigger hole which = more fuel.
When you are done here, screw it all back together. Be sure to put the float bowl gaskets back on or you will have a big mess later.
1. Unscrew these
2. Diaphragm/Vacuum Piston
Unless your carbs have been sitting for years, you probably won't have to touch this side. No fuel enters here (maybe just a little mist) so not much gets gunked, however its rubber and can rot if neglected for years. This side is more for jetting
Hand screw one of the cover screws into the center of the diaphragm to remove it.
1. Jet needle
2. Vacuum piston/Slider
While holding on to the slider, be careful not to bend or break the needle, pull on the screw which you have threaded into the center of the diaphram. Give it a good tug, nothing will break unless you smack the needle off something.
1. Multi slotted jet needle - this is aftermarket and what comes in a jet kit. the clip position on this controls the 5-7.5k RPM range.
2. Plate set - This is the thing you just yanked out of the slider.
This is where you find out if your carbs are OEM or you have a jet kit. ANY alteration to your bikes intake, engine, or exhaust will require a jet kit if you want your bike to function properly.
To change clip positions, lay the needle down on a table like in the picture. Feel free to use another finger on the other side of the clip, and push down. It is a C clip. Do the same thing in order to snap the clip in. Again, be gentle, do not bend your needles.
Jet kits also come with shims (little washers). These shims are used to alter the needle by half of a clip position. All you do is put a shim on the pointy side of the needle down to the clip and drop it back into the slider.
To assemble, just put the needle back in and snap the plate set down into place.
1. Jet needle sliding into needle jet.
Drop the slider gently back into place and be sure that the needle goes into the jet.
Screw the cover back on, and once you are done push down on the sliders, they should resist a little and slide back into position smoothly.
Warning! Do not over tighten ANYTHING on your carbs. Make everything snug but don't put all your might into it. The jets are a very soft metal and easy to ruin, and all of the cover screws can be stripped if you aren't careful.
At this point, you just start putting everything back together. Attach your choke and throttle cables (have fun with that again...), push the carbs down onto the engine and be sure the are seated properly and tighten up the boot screws. Attach your air filter box, breather hoses, air filter, gas tank (don't don't forget the vacuum and fuel lines), seat and fairings.
Edit: Adding a pic and link on reading spark plugs.
Below is a picture of my current spark plugs. This is the best tuning I have yet to achieve. It is tuned for horse power, and thus close to being lean. However, there are no signs of detonation, or over heating therefor it is still safe.
How to read spark plugs: http://www.angelfire.com/fl4/pontiac...Readplugs.html
Enjoy
Old 07-09-2009, 05:49 PM
g32bturbo's Avatar
PLUS 1!!! Sticky.
Old 07-09-2009, 06:51 PM
Sand.Man's Avatar
You just saved me a lot of work, thanks!
You get a sticky, and an A+ for effort.
Old 07-09-2009, 07:28 PM
Dissevered's Avatar
You are quite welcome sir!
Old 07-10-2009, 12:39 AM
swnp101's Avatar
Ok... really cool. I wish I saw this BEFORE I took my carbs off and "winged" a cleaning. I guess I did ok anyway cause I figured all this out on my own, except the Pilot/Slow jet adjustment screw part. (and the Multi slotted jet needle / Plate set removal part :/ )
Anywho, I have a few problems (which I won't get into here) now that everything is together again. What I'm wondering now that I've read this awesome how-to is; what is the effect of screwing in/out the pilot/slow jet adjustment screw? What does it do, exactly?
Does screwing it in give less fuel, and back out more fuel? Or is it air? Is it for the entire rev range? Or mainly at idle/turn over? I'd like to know before I dig back in there and start messing with stuff trying to fix my starting/idle/throttle problem(s).
Thanks again.
(I hope these questions aren't answered in the link you gave, cause I haven't clicked it yet once I saw pictures here!)
Old 07-10-2009, 07:34 AM
Dissevered's Avatar
Yeah, the tuning stuff is in that link. Everything in the carbs is fuel related. Pilot screw in/clockwise is less fuel, out/counterclockwise is more fuel. Setting needle clips to allow the needle to seat far into the needle jet is less fuel, setting clips closest to the needle tip will pull it far out of the seat giving you more fuel. As for the main jet, different ones come with different sizes (based on number), letting more or less fuel into the intake.
Old 07-14-2009, 12:05 PM
STBrider91's Avatar
Thanks for the how to on cleaning the carbs it really helped me out and i really like the pics it is much easier to see what some one is talking about
Old 07-16-2009, 02:42 AM
tigertim20's Avatar
hey fantastic write up! but I have a couple of questions if you could help me out?
in regards to pic 16, and the following comments about the afermarket jet kit.
firstly, I am doing a mod to my exhaust. at the momment my bike has a randon can on it, that at some point has just been thrown onto the bike, so I am getting a straight through tri-oval can, and considering an undertail.. but thats another story....
my question here is, if I do the exhaust mod, will I need to put a jet it in???
Next question, you mention HOW to adjust the clip position on the multi slotted jet needle, but how do I know WHERE exactly to move it to? does the jet kit come with instruction explaining this?
Last question, after I do the exhaust mod, is it best to do Exhaust mod, then carb clean and jet kit, then carb balance/synch in that order?
Any help you guys give me would be greatly appreciated, thanks!!!
Old 07-16-2009, 01:13 PM
Dissevered's Avatar
Pretty much any alteration regarding the engine, air box, carbs, and exhaust will require jetting to be done.
As for instructions, not really. Sometimes they give you a general ball park figure of what to do in certain cases but that is to only get you started, from there it takes a lot of testing and tuning. Your bike will usually still run, which is why many shops are lazy and just throw the jet kit in via instructions and send you on your way with flat spots in your RPMs.
Syncing requires a tool, if you have it, I would throw the exhaust on, clean and get your first jetting adjustment in while you already have it apart, then sync, then ride it. At which point you will most likely have to tear into the carbs again to make more adjustments. View the link at the top of the carb post for more in depth tuning
Old 07-22-2009, 10:37 PM
Brian1993F-2's Avatar
I noticed your float bowls are switched, you would want to switch your on on the far left for the one on the far right. That would allow access to all drain screws without having to take the carbs off or really work around a lot of stuff.
Quick Reply: Carburetor Cleaning & Tuning 101
