Valve Shims
RE: Valve Shims
You can go to just about any dealer. I think you are running 7.5mm shims. Each manufacture makes shims those size, and also aftermarket shims. I think though the thing you want to look for are shims that look like they are harden. There are two types of material I think they make shims in. Sintered like sintered brake pads, and hardened metal ones. I was never sure which was suppose to work for what bikes, but if you get the OEM honda ones you can't go wrong. But i think that hot cams, and the other aftermarket ones use sintered type shims.
