CBR IGNITION??
CBR IGNITION??
yesterday, i was riding my bike all day and it started up fine. Today i try starting my bike but for some reason when i turn on my ignition switch, you don't hear that fuel pump sound that it makes. I thought it would be my fuel gone bad but i checked it and it wasn't my fuel pump. does anyone have an idea what i could do to check what could be the problem?
RE: CBR IGNITION??
fuel pump might just be going.. or did u check relay?
try this..
when/if the fuel pump does not operate, prop up fuel tank, disconnect the fuel pump connecter - it's black, then turn the ignition switch on and mesure the voltage between the terminals
brown is positive + and green is negative -
there should be battery voltage for a few seconds, if there is voltage then replace the fuel pump, if there isn't
then check,
main fuel - 30a
sub fuse - 10a, 20a
fuel cut off relay
bank angle sensor
engine stop relay
ecm
try this..
then check,
main fuel - 30a
sub fuse - 10a, 20a
fuel cut off relay
bank angle sensor
engine stop relay
ecm
