No power
Old 04-07-2013, 05:10 PM
jdub22's Avatar
Default No power
I went to start my bike with a new battery and nothing. The clock in my CBR f4i speedometer is blinking but nothing else. No lights, horn, signal, Nada.It wanted to turn over before I started fixing things on my bike but nothing now. Do I need to strip all of my wiring and rewire it??? Man that is going to be a pain. I imagine its time for a service manual huh?
Old 04-07-2013, 05:25 PM
74demon's Avatar
Is the battery charged? Check your voltage and battery connections first.
Old 04-09-2013, 11:07 PM
jdub22's Avatar
I took an ohmmeter and the battery has power-it is new anyway-so I tested the positive cable where it leaves the battery compartment and enters some sort of junction. It has power up to the junction. Which means its good connection. But the ohmmeter went backwards on the second part of the junction where it branches to the other wires. I mean I have a wire going to my speedo and its clock turns on but nothing else turns on and I mean absolutely nothing. Any ideas?
Old 04-10-2013, 02:18 AM
campos_motorsports's Avatar
If you redid your whole wiring have you check for power at the ignition? Just check it with a current tester to see if it lights up so you can knock that out of the problem.
Old 04-10-2013, 10:40 PM
gpfan1's Avatar
I assume you mean the needle on your meter went in the opposite direction or read in a negative number while reading voltage, right? If so, then something is connected wrong or a part is burned out. Normally DC voltage doesn't fluctuate. You may also have reversed your probes.
Old 04-11-2013, 09:40 AM
jdub22's Avatar
What are probes? With this being an electrical problem it should just because matter of fixing a broken circuit right? It should only because hard as finding the broken link
Old 04-11-2013, 11:57 PM
gpfan1's Avatar
Is your test meter a multi-meter? Probes are another name for the two wire leads that you use to check voltage with.
Old 04-13-2013, 01:07 AM
jdub22's Avatar
OK so I went and acquired a OEM service manual. Read it and after double checking it was the main fuse.... well at least I learned something. I ran into another problem afterwards but am going yo make s different post for it. Thx for the input!
coolbluedab
02-07-2014 07:13 PM
romanboy
01-19-2013 12:53 AM
__Z__
07-14-2010 10:00 AM
Karmakazi
09-29-2009 09:58 AM
Certified Ryder
11-12-2007 10:13 PM
Quick Reply: No power
