Fuel smell
Old 12-26-2012, 08:28 PM
koalaboy's Avatar
Default Fuel smell
hi all i have a 94 cbr1000f and i get a real bad fuel smell after going for a ride when i switch the engine off , any leads would be aprecated , thanks cliff
Old 12-29-2012, 04:04 AM
HenryM's Avatar
Hi Koalaboy,
I'm going to assume you're in Oz, not that it matters but always nice to know where everyone is.
Think of the fuel system as being one continuous tube which runs between the fuel filler on the tank to the jest in the carbs. At any point between either end there is potential for fuel to escape. Even a minute weep will cause a smell.
So to find the leak, start at the top (the tank) and work your way down the tube to the carbs. Check the seal around the filler cap isn't damaged for starters. Check that the tank breather isn't blocked.
I've had a few problems with petrol leaks on both my canes, firstly starting with the tank its self and then on the second bike, the fuel tap had an internal leak through the seals around the valve shaft resulting in petrol leaking out through the tap body. It took me quite a while to suss that one out and the only cure was to replace the whole tap. Replacing the diaphragm made no difference.
Take off the tank and check there's nothing weeping from under the front mounting point. If you detect a petrol leak around this area of the tank you're probably going to have to change the tank. Trying to seal it from the inside is hit and miss and even if you do seal it the chances are that it'll start leaking again as there is a lot of flex between the tank and the bracket when the bike's in motion.
You may be lucky, it could just be a rubber hose further down from the petcock.
Its a process of elimination. Hopefully it'll be pretty obvious.
Good luck.
Old 12-30-2012, 06:06 AM
tobiahr's Avatar
An easy way to locate even a small leak that may only be present when the bike is warm and have evaporated by the time you get it disassembled enough to find it is by using baby powder. Put some in a turkey baster to get in tight spots and powder the carb area being careful not to put any in the airbox or intake. The powder will stick to any wet surface and will absorb the fuel staining it to a yellow or light tan. When disassembling the bike you should be able to spot the leak easier.
Old 12-30-2012, 07:13 AM
HenryM's Avatar
Brilliant idea Tobiahr! Premier league trouble shooting tip.
Amazing what else you can use a Turkey baster for.
dacamman86
07-29-2021 04:10 PM
Contro13R
10-31-2014 11:26 AM
Paradroid
05-06-2013 03:52 PM
tc_rogers
04-19-2012 09:44 AM
crhallcbr
11-15-2007 11:20 AM
Quick Reply: Fuel smell
