Cbr 600 f1 no spark!
Old 12-07-2011, 06:11 PM
sz00's Avatar
Registered Users
Default Cbr 600 f1 no spark!
Hi all,
I've been having a problem with bike since few weeks- it was cutting off suddenly occasionally but still ran, until few days since when it just doesn't start
There is no spark to any of the plugs. I checked by putting a screw driver in the leads(as it is a pain to remove the plugs) and position it very close to the engine while cranking and no sign of spark at all...
I used the manual to do some ignition checks:
I measured the voltage on the CDI 6P(to ensure no faulty switch on the loom) connector and resistance of the ignition primary coil and all of this is normal.
I get a resistance of 3.4 ohms at the primary coil terminals and 14kohms at the secondary coil terminals.
I also checked the resistance of the pulse generator and getting a 540ohms between the wires and 0hms between any of the terminals and the ground which according to the manual is fine.
Everything is leading towards a faulty CDI... Any other suggestions will be appreciated.
I read somewhere before that a fault fuel pump relay could "simulate" fault CDI somehow- didn't make any sense to me but dunno - can anyone think of something?
Also someone else mentioned about a diode in the ignition switch fault - any explanation about this as well?
Please recommend something, as I really hope to not have to buy a new expensive CDI?
Thanks,
Jay
Old 12-08-2011, 05:04 PM
thrasher572's Avatar
Engine kill switch?
Old 12-08-2011, 09:54 PM
tds94probe's Avatar
Originally Posted by thrasher572
Engine kill switch?
x2 the first place to start is take the kill switch apart, clean it, and apply electrical contact grease into it. Its a bad place for corrosion.
Old 12-09-2011, 02:59 AM
sz00's Avatar
Registered Users
This was the very first thing I checked, and the fact that I am getting 12+V on the 6P connector on the CDI is saying that there is no faulty switch on the circuit. Only to be 101% sure I bypassed the switch but same story... I am waiting for another test piece CDI in the following few days so fingers crossed I finally find what the problem is.
Well.. I was hoping it would be a samller (cheaper) problem than the CDI but if it turns out to be this at least I know whats wrong..
Any other suggestions are very welcome and appreciated!
Cheers
Old 12-09-2011, 06:39 AM
sz00's Avatar
Registered Users
The kill switch is fine. I did bypassed it just in case anyway..
I am just wandering which one would it be:
Pulse genetrator sensor or CDI...???
Is it supposed to have oil inside the left engine cover (where the pulse sensor is)?
Old 12-10-2011, 07:00 PM
Bobthebiker's Avatar
yes theres supposed to be oil in that cover I believe.
wha year is your CBR? I'll be partng out my 90 soon.
Old 12-11-2011, 03:32 PM
tds94probe's Avatar
Yes there should be oil in there, when I changed to the +6 Degree Ignition rotor, about a litre came out.
Old 12-11-2011, 04:46 PM
sz00's Avatar
Registered Users
Ok thanks for the info guys!
Just to update: the bike is now ALIVE- it was the CDI unit. It did fire as soon as I pressed the start button after replacing the unit.
Thanks for the answers!
baseballkid
10-04-2012 07:48 AM
cncquinn
05-21-2011 04:55 PM
jaredaamy
01-01-2009 10:51 PM
Bazman
11-23-2008 01:13 AM
w4kr
06-11-2007 04:44 PM
Quick Reply: Cbr 600 f1 no spark!
