clutch noise
Old 07-07-2011, 07:30 PM
csp's Avatar
csp
csp is offline
Default clutch noise
from everything i've read f3's typically have a clutch "rattle". i have developed a different noise this season, though... i have a feeling it is my throw out bearing. it's sort of like a whir or rub whenever the clutch is let out. nothing in neutral, though, either way. if i'm riding and i pull the clutch in it goes away.
i haven't noticed any slip or anything like that, and up until about a month and a half ago it was quiet. anybody have a similar noise or can diagnose it from my description?
Old 07-10-2011, 03:45 PM
csp's Avatar
csp
csp is offline
almost 50 views and no input? not even a "need more info?"
Old 07-10-2011, 10:25 PM
pacemaker's Avatar
I think most of us have thought "Clutch" noise question again.
From what have said, it sounds like the typical noise from the clutch basket. Mine did not rattle, but made the same sort of noise you describe. Most clutch problems will start to have indicators happening, bike creeps forward with the clutch in, slips under load & so on, Clutches usually have a long life, depending on maintenance & abuse.
It may just be in need of an oil change & then its a good time to see if there is any clutch debris suspended in the oil (fibrous material).
I know that when I 1st noticed the clutch noise (& thought "what the f**k is that!) I zeroed in on it until I found out it was normal. Then I concentrated more on getting rid of all the fairing rattles & buzzes (never quite succeeded).
Old 07-10-2011, 10:53 PM
csp's Avatar
csp
csp is offline
ok. yeah i wouldn't have even made a thread but everyone else says rattle so i was semi concerned. thanks for the response.
CKcbr600fm
07-26-2010 05:53 AM
tecatesr330
12-12-2009 10:28 PM
shoemjay
01-20-2008 02:10 PM
Da CbR KiD
07-11-2007 09:08 AM
axsys
06-11-2007 05:48 PM
Quick Reply: clutch noise
