Bleeder screw replacement
Old 05-03-2010, 07:48 PM
Ncat's Avatar
Default Bleeder screw replacement
I want to replace the old rusty brake bleed nipple on the right caliper of my 929 as it is slightly weeping fluid up the thread. (it is as already tight as I dare make it)
Question: When I screw the old bleeder valve out, is the fluid likely to spurt out or just ooze slowly ?
Can I just screw the new bleeder valve in quickly and get away without having to bleed the system ?
Is it ok to use a little teflon tape on a bleeder screw or will it contaminate the fluid ?
Thanks.
Old 05-03-2010, 10:22 PM
justasquid's Avatar
As long as you don't have any pressure on the brake lever, fluid will not spurt out. It will weap out slowly.
Also, you can replace the new bleeder without having to bleed the system. As long as you don't let the resevior empty that is. But you should have a few minutes to do it without worry. However, I would suggest not tightening the bleeder fully until you see fluid coming out the top of the bleeder.
As for putting teflon tape on, there shouldn't be a need. the threads do not seal the bleeder, the end of it does. the end of the bleeder has a tapered end, and the caliper has the mating end at the bottom of the tapped hole. That is where the seal is made, not with the threads. If you have weaping past the threads, the seat may be gulled up. Besides, I don't think teflon tape will hold up to brake fluid, I'm sure it would be eaten away rather quickly.
Replace your bleeder and don't over tighten, and see if the weaping stops. if it doesn't, your seat may be bad and the caliper may have to be replaced.
And no matter what you do, DO NOT press on the lever with the bleeder out. If you do, once the bleeder is released, you will pull in a ton of air into the system. But Im sure you are aware of that, just saying it just in case.
Old 05-04-2010, 02:16 AM
Ncat's Avatar
Thanks Squid..all good tips ! Much appreciated !
Aheroicrevolt
07-14-2011 05:22 AM
Bassman
03-10-2010 10:42 AM
Kuroshio
07-26-2009 10:38 PM
muckdawg24
03-27-2008 09:30 AM
stuntn_r6
03-26-2008 02:46 PM
Quick Reply: Bleeder screw replacement
