bike wont start after warm
Old 09-01-2009, 03:01 PM
Q_714's Avatar
Default bike wont start after warm
need help please...recently my bike won't start after I have ridin it. My bike has no problem starting when its cold. But after I have warmed it up and ride it, it will not start again after I turn it off. No crank nothing...I would have to wait about 10 to 20 minutes sometime to be able to start it up again. can anyone help?
Old 09-01-2009, 04:08 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Info please ... what model?
Old 09-02-2009, 02:09 PM
Q_714's Avatar
I have a 2002 f4i...i also noticed that my bike gets hot around the frame by the gas tank. like really hot ! and my fan dont kick on til about 220 temp. is that normal?
Old 09-02-2009, 02:31 PM
Those are both normal. The frame gets hot due the the regulator/rectifier and the fan should kick on around 220F and go off around 205F.
When a fuel injected bike won't crank when warm it's usually a bad sensor. Either the MAP (manifold air pressure) sensor or the IAT (intake air temp).
Get a hold of a manual ... it will have the specs for you to check out these sensors with a meter.
Old 09-03-2009, 03:52 PM
Q_714's Avatar
kool thx! I will check those out and see. I appreciate the help...I was a lil worried about the heat temp and fan so I got it running always now. I'll fix it back. lol
Old 09-09-2009, 10:37 PM
chrias's Avatar
I have the same issue with my 2002 F4i. I don't think it
s my rectifier because it looks like it's been changed with a Gixxer model. I have to try and bump start the bike. Sometimes it works and when it doesn't I sometimes hit the switch after I've rolled it down the street a bit and it will fire up but really slowly like it wants to die again from lack of voltage. I'm thinking I may have a bad battery.
My whole dash will reset as well. If I hold the starter button down it will crank just a bit and everything will turn off until I release the button then everything will come back on. The starter will not continue to click as if it has low voltage.
Could it still be one of the sensors?
cmasonrun
09-01-2008 04:08 PM
wentsCBR
08-26-2008 07:20 AM
brett82
07-27-2008 01:04 AM
HurricaneRider
04-14-2008 12:32 PM
HurricaneRider
04-12-2008 06:31 PM
Quick Reply: bike wont start after warm
